How Is Tension Distributed in a Multi-Block System?
  • Thread starter Thread starter physicsgrade11
    Confused Tension
In a multi-block system where a girl pulls three blocks with a force of 6 N, the tension in the rope between the first and second blocks is calculated to be 5 N, while the tension between the second and third blocks is 2 N. The weights of the blocks were initially misstated as Newtons but are actually in kilograms. The discussion emphasizes the importance of understanding the relationship between force and mass in calculating tension. Participants express a willingness to share the steps for solving the problem if needed. Overall, the conversation revolves around clarifying the tension distribution in the system.
physicsgrade11
Ok - I was helping a friend out and was helping her with a problem but I am not sure if i was right.
A girl is pulling three blocks with a rope at a force of 6 N . There is two more strings between each block. The first block weighs 0.5 N the second block weighs 1.5N the third block weighs 1 N. Ignore friction. What is the amount of tension on each rope? :confused:
Sorry i made a mistake the weight of the blocks are meant to be in kilograms not N .
lol idiot me...
The force on the rope between the first and second blocks is 5N
And the force on the rope between the second and third blocks is 2N.
I hope that helps
If you need the steps to get the answers, just ask.
lol idiot me...
The unit of weight IS Newton, though..
I hope that helps
hey... how'd u do it?
thanks much
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
