How Long to Fill Tank with 3 Pumps?
  • Thread starter Thread starter gloppypop
    Tank Water
The problem involves three pumps filling a tank at different rates: Pump A fills the tank in 15 minutes, Pump B in 30 minutes, and Pump C in 60 minutes. When all three pumps operate simultaneously, their combined rate is calculated as 1/15 + 1/30 + 1/60, resulting in a total filling time of 8.57 minutes. However, this calculation is incorrect; the correct approach is to find the least common multiple of the filling times to determine the actual time taken. The accurate time to fill the tank with all three pumps is 10 minutes.
  • Understanding of rates and ratios in fluid dynamics
  • Basic algebra for combining rates
  • Knowledge of least common multiples (LCM)
  • Familiarity with problem-solving techniques in physics
  • Study the concept of rates in fluid dynamics
  • Learn how to calculate least common multiples (LCM)
  • Practice problems involving multiple rates working together
  • Explore the application of algebra in real-world physics problems
Students in physics or mathematics, educators teaching problem-solving techniques, and anyone interested in understanding fluid dynamics and rate calculations.
gloppypop
Three pumps are attached to a three-dimensional tank. They pump water into the tank at a constant rate.
Pump A when turned on alone fills up the tank in 15min.
Pump B when turned on alone fills up the tank in 30min.
Pump C when turned on alone fills up the tank in 60min.
If ALL THREE pumps are turned on at the same time, how long will it take to fill up the tank?
The volume of the tank doesn't matter in this question. So I tried to find the rates at which each pump filled up the tank.
Pump A: Rate A = 1 tank/15min
Pump B: Rate B = 1 tank/30min
Pump C: Rate C = 1 tank/60min
I then added the rates, since they are each constant: Rate A + Rate B + Rate C = 7tank/60min = 1 tank/8.57min.
8.57 min to fill the tank with all three pumps turned on. This was incorrect.
I'm kicking myself because I've already taken classical mechanics and a sufficient amount of math courses, yet I can't seem to think out this simple problem.
The answer seems right to me. If you think about the time taken to fill the tank will all the pumps filling simultaneously, is less than that taken by the pump A which has highest rate as it should be. This is just ratio proportion kind of problem. I think you are making it complicate by thinking about classical mechanics.
Yes, this has to be right... My classmate was telling me it was wrong and it had me really irked. Thought I was goin crazy for a minute.
Thanks =]
  • · Replies 22 ·
