How long will it take the zinc to reach the desired thickness?
  • Thread starter Thread starter rayhan619
    Thickness Zinc
The discussion focuses on calculating the time required to electroplate a 130 nm thick zinc coating on both sides of a copper sheet using a current of 1.3 mA. Initial calculations led to a time of approximately 3.84 seconds, but the user later revised their calculations to 3846 seconds after correcting the number of moles and electrons involved. There is an emphasis on ensuring unit consistency, particularly between kilograms and grams. The final result of 3846 seconds for both sides was confirmed as correct, although concerns about significant figures were raised. The user is still uncertain about the accuracy of their final answer.
rayhan619
For a science experiment you need to electroplate a 130 nm thick zinc coating onto both sides of a very thin, 3.0 cm*3.0 cm copper sheet. You know that the charge carriers in the ionic solution are divalent (charge 2e) zinc ions. The density of zinc is 7140 kg/m^3
If the electroplating apparatus operates at 1.3 mA, how long will it take the zinc to reach the desired thickness?
we know area and thickness of the plate and the density of the zinc, and the current.
so we can get the volume of the plate and using density we can figure out the mass.
volume = 3*10^-2* 3*10^-2* 130*10^-9 m = 1.17*10^-10 m^3
and the mass = 1.17*10^-12 m^3 * 7140 kg/m^3 = 8.35*10^-7 kg
in 1 mole the weight of zinc is 65.38 g
so in 8.35*10^-7 kg 1.3*10^-8 mole
1 mole we have 6.022*10^23 atoms
so in 1.3*10^-8 mole we have 1.3*10^-8 * 6.022*10^23 = 7.83*10^15 atoms
so number of electrons = 7.83*10^15 *2 = 1.57*10^16
1 Coulomb is equal to 6.241*10^18 electrons.
so 1.57*10^16 electron = 2.5*10^-3 C
I = Q/t
so t = Q/I
= 2.5*10^-3/1.3*10^-3
= 1.92 s
so for both side the total time would be 1.92*2 = 3.84 s
i tried plugging that number but apparently it was wrong.
Any ideas what i am doing wrong in here?
Any help would be appreciated.
Check the units, both kg and g appear here. Use one or the other.
yes you are right.
i redo the part.
does it look good?
so in 8.35*10^-7 kg 1.3*10^-5 mole
so in 1.3*10^-5 mole we have 1.3*10^-5 * 6.022*10^23 = 7.83*10^18 atoms
so number of electrons = 7.83*10^18 *2 = 1.57*10^19
so 1.57*10^19 electron = 2.5 C
I = Q/t
so t = Q/I
= 2.5/1.3*10^-3
= 1923 s
so for both side the total time would be 1923*2 = 3846 s
Looks good! Just watch the sig figs.
i tried putting 3.8*10^3 s
but that didnt work either.
donno what's wrong with this problem. : (
