How many elementary charges does this particle carry?
The discussion centers on calculating the charge of an unknown particle subjected to a magnetic field, using the formula Fm=qvB, which leads to a charge of approximately 7.986 x10^-19 C. To determine the number of elementary charges, users clarify that this value should be divided by the elementary charge, approximately 1.602 x10^-19 C. Additionally, the conversation addresses the calculation of the radius of an alpha particle's circular path in a magnetic field, confirming the use of the formula r=(mv)/(qB) as correct. Participants share information about the charge of an electron and express agreement on the calculations. The thread effectively combines physics concepts with practical problem-solving.
Kylah
1. A force of 9.2x10-14 acts on an unknown particle that travels at 2.40x106 m/s into a magnetic field of 4.8x10-2 T. How many elementary charges does this particle carry?
I've used Fm=qvB and found q=Fm/vB and got an answer of q=7.986 x10-19 C. I'm not sure where to go from here. I assume I have to divide by the elementary charge... but I don't know what that is. Haha.
2. An alpha particle with a charge of 3.20x10-19 C and a mass of 6.65 x10-27 kg is traveling at 5.0 x106 m/s. When it enters a magnetic field of 6.4 x10-2 T, a magnetic force provides the centripetal force for the alpha particle. The centripetal force causes the alpha particle to travel in a circular path. Calculate the radius of the circular path.
Do I simply use the equation r=(mv)/(qB)?
The elementary charge is the same as the magnitude of the charge of an electron, about 1.602×10-19 C.
Sounds good to me :approve:
1. the charge on an electron is -1.602 176 487 × 10–19 C
2. Yes, that's the correct formula.
Thanks! :smile:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
