How many volts can a multimeter read?
  • Thread starter Thread starter Inventor man
    Multimeter Volts
Multimeters can read various voltage levels depending on their specifications, with some models capable of measuring up to 1000V DC. The user inquired about the limits of their inexpensive multimeter, which has a range starting at 1000V DC. It is important to refer to the owner's manual for specific limits and scales, as different multimeters can vary significantly. The discussion emphasizes that the scale is often printed on the device itself, providing clarity on its capabilities. Understanding the multimeter's specifications is crucial for safe and accurate measurements.
Inventor man
I have only tested mine (it is a cheap one $20) it on a 9V battery, what is the limit?
My multimeter starts from 1000V DC then 200,20, 2000m,200m...
I am a noob with this so sorry if I don't make sense
I'm afraid that different multimeters have different scales. Your meter should have an owners manual. What does that say?
Sounds from the description like it has the scale printed on it and we already know the answer!
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
