How much gas is required to heat a house
  • Thread starter Thread starter Dyna
    Gas Heat
To determine the amount of gas needed to heat a house requiring 2.0 x 10^9 kJ for the winter, one must account for the furnace's 80% efficiency. The heat of combustion for methane is given as 5.5 x 10^7 J/kg. To find the required energy input, the formula for efficiency can be applied, leading to the calculation of the necessary joules of combustion heat. Once the total energy input is established, it can be converted to kilograms of methane needed for heating. Understanding these calculations is crucial for accurately estimating gas requirements for home heating.
Dyna
1. Methane has a heat of combustion of 5.5 x 10^7 J/kJ.
a)How much gas is required to heat a house that requires 2.0 x10^9 kJ for the whoel winter? Assume that the furnace is 80% efficient
3. So i tried dividing using Q=mL
but i don't seem to be getting the right answer (4.5 x 10^5)
I also tried using the efficiency formula but that doesn't make sense =\
There is also part b and c but those are reliant on this answer so I'm trying to focus on it but i simply don't understand what i should be doing
(NOTE: Your units are wonky. The heat of combustion is: 5.5 x 10^7 J/kilogram)
How many joules of combustion heat do you need (this is where the efficiency comes in).
If you get that, it is a simple matter to figure out how many Kg of methane you will need.
AM
So..the house needs 2.0 x 10^9 kJ...
so thats...( 2 x 10^12 x .8) = e/ m
what woudl E be here - 5.5 x 10 ^7 ?
I am not sure what unit that is supposed to be. But I'd start by finding the energy input using the formula for efficiency.
EDIT: well I was beaten to it, but Andrew Mason has the idea.
Right, so that is how much energy the methane outputs
Efficiency = useful output / input x 100%
.8 = 2.0 x 10 ^12 J / input x 100%
no i have no idea what I am doing XD help?
80 = 2.0 x 10 ^12 J / input x 100%
Find the input energy perhaps.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
