How Much Work is Done Pushing a Sled Up an Incline?
To determine the work done pushing a sled up an incline, the force must be calculated using the sled's weight and the incline's angle. The sled, with a combined weight of 35 kg, exerts a force of 343 N due to gravity. The normal force is then adjusted for the incline using the cosine of 15 degrees. The definition of work is clarified as W = Fd or W = Fd cos(theta), which is essential for solving the problem. Understanding these concepts is crucial for accurately calculating the work done against gravity and friction.
ICEMANN6859
FATHER PUSHs IS DAUGHTER ON A SLED UP A SNOWY INCLINE. IF THE SLED MOVES UP THE HILL WITH A CONSTANT VELOCITY how MUCH WORK IS DONE?
CHILD & SLED= 35KG FRICTION OF SNOW & SKIDS= .2 INCLINE= 15 DEGREES, d=10 m
Do i need to find the force? (N=mg)
and then Ncos15degrees?
I don't know how to get started.
Have you made any attempt to answer this question? You must show some work before we can help you. Also, in future, would you please write in lower case: upper case is considered to be shouting.
Yes I have, but I'm not getting the same answer as in the book.
Sorry about the upper caps.
35kg*9.8= 343N
343N cos 15 degrees = .97
What is the definition of work?
Casey
definiton of work is W=Fd
or W=Fd = (Fcos thete)
