dannyPhysics
- 6
How time Travel work ?
ok i know some of the basic about speed of light...
You can't get to the speed of light ...
You can't reach the speed of light cause According to Einstein's special theory of relativity, and E= MC ^2 objects gain mass as they accelerate to greater and greater speeds. Now, to get an object to move faster, you need to give it some sort of push. An object that has more mass needs a bigger push than an object with less mass. If an object reached the speed of light, it would have an infinite amount of mass and need an infinite amount of push, or acceleration, to keep it moving. No rocket engine, no matter how powerful, could do this. In fact, as far as we know, nothing can exceed the speed of light.
And i know how it work
Imagine you're standing on Earth holding a clock. Your friend is in a rocket zooming past you at nearly 186,000 miles per second. Your friend is also holding a clock. If you could see your friend's clock, you'd notice that it seems to be moving a lot more slowly than yours. Your friend, on the other hand, thinks the clock in the rocket is moving just fine, while your clock on the ground seems to be moving very fast. Test it out ?
Atomic clocks are extremely accurate clocks that can measure tiny amounts of time—billionths of a second. In 1971, scientists used these clocks to test Einstein's ideas. One atomic clock was set up on the ground, while another was sent around the world on a jet traveling at 600 mph. At the start, both clocks showed exactly the same time.
What happened when the clock flown around the world returned to the spot where the other clock was? As Einstein had predicted in a general way, the clocks no longer showed the same time—the clock on the jet was behind by a few billionths of a second. Why such a small difference? Well, 600 mph is fast but still just the tiniest fraction of the speed of light. To see any significant differences in time, you'd have to be traveling many millions of miles an hour faster. If you are moving time will slow down, even you in Earth or out of space
but my big big question is, how Speed of light (C) or speed have anything to do with time ? what is time ? i mean How time slow down ?? How time can slow down when travel ?hope u guy can explain for me
