How to calculate critical atom density of a slab reactor?
To calculate the critical atom density of a 150cm thick slab reactor composed of U235 and graphite, one must first determine the mass of the moderator by multiplying the volume of the reactor by the density of graphite. Since the slab reactor is defined only in width, it is essential to assume a semi-infinite reactor model, which simplifies the analysis by considering neutron leakage only in the direction normal to the slab. The criticality condition involves macroscopic cross-sections, represented as Nσ, and requires solving for critical buckling using the equation B²_M = (νΣ_f - Σ_a)/D. For a one-dimensional slab, the geometric buckling is given by B²_G = (π/a)², where 'a' is the slab thickness. Understanding these parameters is crucial for accurately calculating the critical atom density.
dss91
I am given a critical bare slab reactor 150cm thick (a0=150cm) consisting of a homogenous mixture of U235 and graphite.
I am stuck on the part which asks me to calculate the critical atom dennsity. I have solved for the mass of the fuel in terms of the mass of the moderator. I would solve for the mass of the moderator by multiplying the volume of the reactor by the density of graphite and then plug that into the relation I have found for the mass of the moderator and the mass of the fuel, however since a slab reactor is defined only in width, I'm not sure how to find the volume of the reactor.
Thanks for any help.
Is one to assume a semi-infinite reactor. The there would be no leakage of neutrons in the lateral directions. One only needs to consider leakage in the normal direction (normal to the slab).
Criticality is usualy defined in terms of Ʃ (macroscopic cross-sections) which are simply products, Nσ.
Usually, the semi-infinite reactor parameters are calculated per unit infinite length. But i think that u should give us the problem for more help
You want to solve for critical buckling, so that B^{2}_{M}=B^{2}_{G}.
B^{2}_{M}=\frac{\nu\Sigma_{f}-\Sigma_{a}}{D}
You are assuming no leakage in the lateral directions so the geometric buckling for a 1-D slab is simply:
B^{2}_{G}=(\frac{\pi}{a})^{2}
where a is the slab thickness.
Hello, I'm currently trying to compare theoretical results with an MCNP simulation. I'm using two discrete sets of data, intensity (probability) and linear attenuation coefficient, both functions of energy, to produce an attenuated energy spectrum after x-rays have passed through a thin layer of lead. I've been running through the calculations and I'm getting a higher average attenuated energy (~74 keV) than initial average energy (~33 keV). My guess is I'm doing something wrong somewhere...
