How to control velocity in a conical pendulum
To control velocity in a conical pendulum experiment, the formula v = 2πr/T is used to calculate velocity based on radius (r) and period (T). To maintain consistent velocity while varying mass, adjustments to r and T must be made, which can be determined through trigonometry and timing measurements with a stopwatch. The mass itself does not directly factor into the velocity calculation but influences the radius and period. Since the experiment involves manual spinning, precise control may be challenging without a velocity measuring device. Understanding the relationship between these variables is key to successfully managing velocity in the experiment.
May
I'm doing an EPI on horizontal circular motion and for one test the independent variable is mass and I need to control the velocity by using the 2πr/T formula. So I know how to use the forumula to find an unknown but how do I use it for two unknowns (r and T). Is there a forumula with M in it that would help?. Because the r will be different for the different masses and so will the T. I'm really confusing myself now, but I guess my question is how do I control velocity in the experiment.
IV: mass, length of string
CV: velocity ...
DV: angle
P.S I'll be spinning it by hand and don't have access to a velocity measuring device (unless its an app or something)
Am I missing the point completely?
Thanks for any help you can give
You use ##v=2\pi r/T## to find the velocity, not control it.
You can find r using some trigonometry and you measure T with a stopwatch.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
