How to design a slide switch mechanism to be waterproof -- ideas?
To design a waterproof slide switch mechanism, several approaches were discussed, including enclosing the slide handle in a polymer boot for protection. A reed switch activated by a sliding magnet was suggested as a way to keep electronics safe from water while allowing operation. Another idea involved using optical sensors to achieve similar functionality without direct exposure to water. Participants emphasized the importance of considering the switch's size, throw length, environmental conditions, and orientation in the design process. Overall, the discussion focused on innovative solutions to create a reliable waterproof slide switch.
Aurimas
I need to protect electronic parts in case from water. The thing is, I need to design slide switch on the cap of the housing. Maybe any ideas?
These folks enclose the slide handle in a polymer boot.
https://www.e-switch.com/product-catalog/sealed/product-lines/500r-series-slide-switch-sealed-to-ip67
above found with:
https://www.google.com/search?&q=+waterproof++slide++switch
(that's putting {+waterproof +slide +switch} in the Google search field. Without the {})
Likes Asymptotic and Aurimas
Welcome to pF.
Maybe you could use a reed switch with a sliding magnet.
The magnetic field will separate the protected electronics from the external water environment.
Likes Asymptotic, hutchphd, berkeman and 1 other person
I had a similar idea, but using optical sensors...
Welcome to the PF. :smile: Can you say more about what you are trying to do? How big of a slide switch, with how long of a throw? What is the environment (other than wet)? What is the illumination like, and what else is nearby the switch? What is the orientation of the switch (horizontal throw, vertical throw, etc.)?
Likes Asymptotic
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
