How to Design an Energy Detection Device for Home Consumption Reduction?
The discussion centers on designing an energy detection device for home use that can automatically switch off unnecessary loads when energy consumption exceeds a set threshold. Participants highlight the challenge of identifying which appliances should be monitored, as many only consume high energy intermittently, such as refrigerators and ovens. The original poster seeks a grassroots explanation of the design process and specific components needed for the device. Suggestions include using a thermostat to manage energy consumption effectively. Overall, the conversation emphasizes the need for clarity on monitoring specific appliances and the technical aspects of the device's design.
Ron_04
hi...i want to design a energy detection device fror my home...i want to design it in a way tht it will also automatically switch off unnecessary load when consumption is high above the set value...can anybody help me with the design please...it wud be better if the xplanation is from grass root level...thanx in advance
Start by describing the problem you want to solve and not the method by which you want to solve it. You know there are lots of different kinds of energy right? From context I guess you want to track electrical energy consumption by your house and switch off particular loads should you exceed some value either for total consumption or rate of consumption?
yep ok that's a standard style of energy monitor
my question would be how to determine when a given load is unnecessary ?
many household items are not contineously running anyway... think of your fridge/freezer or hot water heater. both power up in bursts for relativel short periods of time. Your oven/range top is only using power when you switch on an element.
Any appliance presenting a load will only have high consumption when its in use... so what's the point of switching it of when you are actually trying to use it ?
so which specific appliances etc were you wanting to consider automatically monitoring ?
Dave
A thermostat is one of the best ways of regulating the energy you use. Turn it down and put on a jumper.
Dave
ok i got ur question...i am giving u an example...suppose high consumption is takin place so the monitor should be so designed it caN reduce the load suppose by increasin thge temp of an air conditioner...i think u got it...so finally i want to knw how to design it ...can u mention what parts i require to design it?
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
