How to Determine θ for a Sliding Block Sticking to a Pivoting Rod?
To determine the angle θ for a sliding block that sticks to a pivoting rod, conservation of energy is applied to find the angular velocity (ω) of the rod at the moment of impact. The block, weighing 60 g, slides down a height of 20 cm before colliding with the rod, which has a mass of 105 g and a length of 40 cm. The initial and final angular momentum equations are utilized to analyze the system's motion. The discussion highlights the importance of correctly applying these principles to solve for θ. Ultimately, the solution was reached successfully.
Roddie031
In the figure below, a small 60 g block slides down a frictionless surface through height h = 20 cm and then sticks to a uniform rod of mass 105 g and length 40 cm. The rod pivots about point O through angle θ before momentarily stopping. Find θ.
(Picture attached)
Li=Lf, L=I[omega]
I used conservation of energy to find [omega] as the block hits the rod, but I'm not sure if that's right or where to go from there
I finally solved it! Thanks anyway!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
