I How to determine the energy of photons released in decay
nwfusor
What equation would I need to use to determine the energy of photons released when radio-isotopes decay? I would like to figure out the energies of photons released when tritium and plutonium 237 decay.
There is no "equation". While it is possible to get some estimates via nuclear models, the most precise results are usually from experiments, and you can check the published material.
Note that tritium has a very low-energetic beta decay, the emission of photons is rare and those cannot have a high energy.
Pu-237 mainly decays via electron capture, you can calculate the maximal photon energy via energy conservation, but the emission of an electron is also a common result, which can but does not have to be accompanied by the emission of photons.
Based off of your answer, would a gamma spectrometer be an effective manner to show that H3 or Pu237 are present?
With that being the case, what would be a good method to do so?
You have a different thread about it, please continue there.
You clearly do not have the required knowledge to work with potentially radioactive material safely anyway.
Likes berkeman
Toponium is a hadron which is the bound state of a valance top quark and a valance antitop quark. Oversimplified presentations often state that top quarks don't form hadrons, because they decay to bottom quarks extremely rapidly after they are created, leaving no time to form a hadron. And, the vast majority of the time, this is true. But, the lifetime of a top quark is only an average lifetime. Sometimes it decays faster and sometimes it decays slower. In the highly improbable case that...
I'm following this paper by Kitaev on SL(2,R) representations and I'm having a problem in the normalization of the continuous eigenfunctions (eqs. (67)-(70)), which satisfy \langle f_s | f_{s'} \rangle = \int_{0}^{1} \frac{2}{(1-u)^2} f_s(u)^* f_{s'}(u) \, du. \tag{67} The singular contribution of the integral arises at the endpoint u=1 of the integral, and in the limit u \to 1, the function f_s(u) takes on the form f_s(u) \approx a_s (1-u)^{1/2 + i s} + a_s^* (1-u)^{1/2 - i s}. \tag{70}...
