How to do Undergraduate Engineering Research?
To begin research in aerospace/aeronautic engineering, focus on gaining a solid foundation in your coursework and seek guidance from professors about their projects. Engaging in volunteer opportunities within research groups can help identify your interests and strengths. Reading academic papers may be premature at this stage, as understanding the technical vocabulary is crucial. Instead, prioritize doing well in classes and consider exploring alternative textbooks for deeper insights. Building technical competence and initiative will impress graduate school committees in the future.
WK95
What should I research? By this I mean, what needs any researching in the first place?
I'm interested in aerospace'aeronautic engineering particularly the areas of structures and aerodynamics. But how do I find out what specific area of it to research? I'm only in my second year of college as a Mechanical Engineering major so I don't know nearly enough to understand the technical details of what ought to be researched. Since engineering is very technical, doing research in the field likely requires strong technical competence which is likely to only be full developed for the undergraduate towards the end of his coursework.
Simply put, how do I get started with research and learn to produce research that impresses graduate school committees?
Doing engineering requires strong technical competence and proficiency. Note what it takes to be a licensed professional engineer (PE).
As for research, one can read any number of journals in various engineering disciplines, and even various disciplines of mechanical engineering.
There is plenty of research in mechanics of materials, computational physics/mechanics, thermal physics (heat transfer), fluid mechanics/dynamics, . . . .
http://asmedigitalcollection.asme.org/journals.aspx
http://appliedmechanics.asmedigitalcollection.asme.org/journal.aspx
Go on your schools database and try to find papers relevant to your field/interests. I try to read 1-2 papers a week if time allows. Learning a programming language is probably a good idea since it's a useful skill in many research groups.
For undergrad I would try to read a variety of topics before trying to focus on one, you never know what you may find interesting. Talk to some professors in your department and see if they wouldn't mind letting you volunteer in their research group.
I'm electrical/computer systems so I'm afraid I can't recommend interesting topics in mechanical.
I think I'll try to learn Matlab since that seems to be a very important software that Aerospace Engineers use.
I'll also take up your suggestion of reading a paper or two a week. That sounds like a good way to dive deep into it and gradually learn some of the stuff.
As a second year you're way too early on in your career to have a feel for what "needs any researching" or what your strengths are. You need to do a long apprenticeship under the advisement of a professor. What classes have you enjoyed? What research interests in your professor's biographies sound interesting? Go around to their offices and ask if they have any projects for undergrads. If you're lucky you can get some time running simulations or checking code for grad students. Slowly you'll learn what your interests are and you can pursue them in grad school.
Grad school committees like good grades and initiative. Look into the SULI program for the DOE to get involved in summer research at a National Lab. There usually aren't too many engineering applicants so your chance of getting an appointment are good.
I disagree you should be reading a lot of papers. As a second year you haven't even learned the vocabulary of the state-of-the-art in Mechanical Engineering and it will be impossible to understand, much less place into context, any papers you read. If you dive too deep before you learn to hold your breath you'll drown.
Do the best you can in your courses and try reading an alternate textbook for your more challenging courses in addition to the textbook assigned. Different textbooks have different approaches and reading multiple ones can give you more insight.
Likes WK95
Hey, I am Andreas from Germany. I am currently 35 years old and I want to relearn math and physics. This is not one of these regular questions when it comes to this matter. So... I am very realistic about it. I know that there are severe contraints when it comes to selfstudy compared to a regular school and/or university (structure, peers, teachers, learning groups, tests, access to papers and so on) . I will never get a job in this field and I will never be taken serious by "real"...
Yesterday, 9/5/2025, when I was surfing, I found an article The Schwarzschild solution contains three problems, which can be easily solved - Journal of King Saud University - Science ABUNDANCE ESTIMATION IN AN ARID ENVIRONMENT https://jksus.org/the-schwarzschild-solution-contains-three-problems-which-can-be-easily-solved/ that has the derivation of a line element as a corrected version of the Schwarzschild solution to Einstein’s field equation. This article's date received is 2022-11-15...
