Dixanadu
- 250
- 2
Hi guys,
So textbooks have it that: "Two Lagrangians differing by a total time-derivative of a function of the coordinates are equivalent". I have no idea what that means or how to use it; so I don't know which terms I can drop from Lagrangians, which is a bit of a problem.
For example, consider a random example... a simple pendulum of length l and mass m. I'll spice it up a bit by saying that the point of suspension can move vertically according to the law y = la(t), where obviously a is a function of time.
If you consider the angle between the pendulum and the vertical, θ, to be the degree of freedom, you end up with the Lagrangian:
L = T - V = \frac{1}{2}ml^{2}[\dot{a}(t) - 2sin(θ)\dot{a}(t)\dot{θ}+\dot{θ}^{2}] - mgl[a(t) + cos(θ)]
Could you please explain what that "differing by a total time-derivative of a function of the coordinates..." thing means by demonstrating on this example Lagrangian which terms I can drop? or any other way you think is best? You don't HAVE to demonstrate on this particular example, I just thought it might help if you had a Lagrangian to play with.
Thanks a lot!
Thanks a lot!
