How to Find Kinetic Energy and Speed of a Particle in a Hemispherical Bowl?
  • Thread starter Thread starter sailsinthesun
    Particle
To find the kinetic energy and speed of a particle in a hemispherical bowl, the gravitational potential energy (PE) at point A is calculated as 0.59241 J. At point B, the potential energy is zero, and the kinetic energy (KE) is equal to the initial potential energy due to conservation of energy principles. The speed at point B can be determined using the formula KE = 0.5mv², allowing for the calculation of velocity. At point C, the potential energy is calculated as 0.39494 J, and the kinetic energy can be derived from the total energy conservation equation. Understanding these relationships is crucial for solving the problem effectively.
sailsinthesun
[SOLVED] Particle in hemispherical bowl
A 195 g particle is released from rest at point A along the horizontal diameter on the inside of a frictionless, hemispherical bowl of radius R = 31.0 cm.
http://www.webassign.net/pse/p8-52.gif
(a) Calculate the gravitational potential energy of the particle-Earth system when the particle is at point A relative to point B.
(b) Calculate the kinetic energy of the particle at point B.
(c) Calculate its speed at point B.
(d) Calculate its kinetic energy when the particle is at point C.
(e) Calculate the potential energy when the particle is at point C.
(a)PE=mgh so PE=.195kg*9.8m/s^2*.31m=.59241J
(b)KE=.5mv^2 but I have no idea how to find the velocity at the point. Any help?
(c)Needed to answer B..
(d)Also need to know how to calculate velocity at this point...
(e)PE=mgh=(.195kg)(9.8m/s^2)(.2067m)=.39494
Any help on b, c, and d?
Hi sailsinthesun!
(a) and (e) seem ok.
KE=.5mv^2 is the answer to (b)! That's all (b) asks you for!
For (c) and for (d), you use "conservation of energy": KE + PE = constant (which, btw, should be in your "Relevant equations"). :smile:
B) At point B the PE is 0 and due to the conservation of energy KE is the same as the answer to A.
C) Now knowing what KE is work backwards with KE=.5mv^2 to find the velocity.
D) Also due to the conservation of energy, in A you found PE and since KE was 0 the entire energy of the system KE + PE = .59241J. So having the PE you found in part E you can substitute and find the KE.
