How to find the maximum angle of a pendulum after a mass collides with it
To find the maximum angle of a pendulum after a mass collides with it, the problem involves a 10g ball fired at 6 m/s into a 280g pendulum with a radius of 28cm. The effective approach requires considering the collision phase and subsequent motion, assuming the masses stick together post-collision. The calculation of height (h) using the equation 1/2mv^2 = mgh resulted in an unrealistic value, indicating a misunderstanding of energy conservation in the collision. It's essential to clarify whether the collision is elastic or inelastic, with the context suggesting a perfectly inelastic collision. Understanding these dynamics is crucial for accurately determining the pendulum's maximum swing angle.
SMilo
A 10g ball is fired at 6 m/s into a 280g pendulum. What maximum angle will the pendulum swing to if the effective radius of the pendulum is 28cm?
How to find theta?
I converted 28cm to 0.28m; 10g to 0.010kg; and 280g to 0.280kg. I used the equation 1/2mv^2 = mgh to find h to be 1.835. Then I plugged it into inverse cos but get a domain error, like so cos^-1(1.835/0.28).
You know that there are 2 different masses? One mass for the bullet, and one for the combined bullet+pendulum.
You need to break the process into two phases: the collision and the subsequent motion.
It does not say so, but you should assume the masses stick together, or at least, have the same velocities just after the collision. Otherwise you do not have enough information.
Your value for h is more than twice the radius of the pendulum.
An observation arising from alternate method:
After the "collide and coalesce" collision , there is virtually no energy left to lift the combined mass. Energy loss calculated as 1/2 μ Δv^2 where:
μ=m1 * m2 / (m1 + m2) and Δv is the relative velocity of colliding objects - in this case 6m/s.
However it's not really clear from the question whether this is an elastic or inelastic collision. My reading of "fired into" is that it's a perfectly inelastic collision.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
