How to integrate x^2 / (xsin(x) + cos(x))
  • Thread starter Thread starter harimakenji
    Integrate
harimakenji
int [x2 / (x sin x + cos x)2]dx
integration
can anyone help me to start?
thank you very much
Hint:(cos(x)/x)'= (-xsin(x)- cos(x))/x^2
I am not sure it helps though.
Note that
d\left(\frac{1}{x \sin x+\cos x} \right) = - \frac{x \cos x \, dx}{(x \sin x+\cos x)^2}
and use integration by parts.
fzero said:
Note that
I am still not getting your hint. When using integration by parts, I have to choose u and dv. I don't know how to choose u and dv for this question.
How to apply your hint to solve this question?
thank you very much
thank you very much
Try
v = \frac{1}{x \sin x+\cos x} .
u will be whatever is left over in the original integrand after rewriting it in terms of dv. u will not look like something nice to integrate, but v du is fairly simple.
fzero said:
Try
I got it. I have tried u = (x / cos x) before and was really unsure that this was the right method, but as you said, it really became a simple integration. I gave up before trying to find the term v du, can't let it happen anymore.
Thank you very much for your hint and help. I really appreciate it.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
