How to make a function continuous
ammsa
consider the function f(x) = (4 - x) / (2 - \sqrt{x}). define a new function g(x) = f(x) for all x except 4 and such g(x) is continuous at 4.
i got the limit of the f(x) when x approches 4 and i got 4 as the final answer.
here's how i did it,
1) (4-x) / (2 - \sqrt{x} )
2) (2 + \sqrt{x}) (2 - \sqrt{x}) / (2 - \sqrt{x})
3) (2 + \sqrt{x})
4) when we plug in 4 in the equation (2 + \sqrt{x}), we get
(2 + \sqrt{4}) = 4
so, g(x) = f(x) when x \neq 4
and = (2 + \sqrt{x}) when x = 4
now my question is is my way of approching this problem correct, and is my answer correct?
I'd say your way of approaching the problem is correct, since it got the correct answer.
hi ammsa! :smile:
(have a square-root: √ :wink:)
yup, your steps 1) to 4) are perfect :approve:
(but in the last line it would be simpler to say "g(x) = 4 when x = 4")
By the way, we would say that the function
f(x)= \frac{x- 4}{x- \sqrt{2}}
has a 'removable' discontinuity at x= \sqrt{2}. That is why it was possible to make it continuous.
It is also correct that the g(x)= x+ \sqrt{2} is NOT the same function as f.
Some people make the mistake of writing
\frac{x-4}{x-\sqrt{2}}= \frac{(x-\sqrt{2})(x+\sqrt{2})}{x- \sqrt{2}}= x+ \sqrt{2}
but that last inequality is only true for x\ne \sqrt{2}and not for all x.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
