Electrical How to maximize the efficiency of the corona discharge generator
The discussion centers on using a Wimshurst electrostatic generator to create a corona discharge. It is noted that removing the metal spheres connected to the generator's shaft may still allow for corona discharge at the tip of the conducting part, primarily due to the high curvature at that point. However, while the discharge may still occur, it is suggested that it would not be stronger than with the spheres, as they help manage the electric field strength necessary for effective discharge. For enhanced corona discharge, replacing the spheres with a sharp point, like a sewing needle, is recommended, as this would concentrate the current density at the tip. To determine which conductor part will be negatively charged, using a Neon lamp or a simple electrical tester is advised, as these tools can indicate polarity by showing a glow at the negative electrode when DC voltage is applied. Additionally, for practical demonstrations of corona discharge, observing high-voltage power lines at night or searching for relevant videos online can provide visual insights.
Christofer Br
Hi, I have a wirmhurst electrostatic generator and I want to use it to create a corona discharge. My common sense tells me that the metal "shaft", which connects to the metal spheres should lead to significant (electron) leak, since it has a much smaller radius of curvature than said spheres. If I removed those spheres, would the corona discharge still be present mainly at the "tip" of the conducting part and would it be stronger, or are those metal spheres actually helping to concentrate the corona discharge in one spot?
Also, how to know which of the two conductor parts will be nagetively charged?
I'm sorry you didn't attract any answers.
I believe that the answers to that is, "Yes"
No.
But I do not have references or calculations to support those answers. They are just educated guesses.
Likes Tom.G
To expand on the correct responses from @anorlunda:
As you are aware, the most discharge will be at spots of high curvature. This is because the strength of the electric field is higher there. The ball electrodes are used to keep the electric field lower so enough voltage can build up to jump the spark gap. Since you are after a corona discharge, replace the balls with a sharp point; you could even just tape a sewing needle to the existing balls!
As for the corona discharger being "stronger", that depends on how you define stronger. The voltage will be lower but the current density will be higher, that is the current will be concentrated at the tip of the needles. If you want a higher current, try spinning the Wimshurst disks faster.
You can use a Neon lamp to test polarity, one of those $5 electrical testers to check if a wall outlet has power would work. A Neon lamp is sometimes called a "negative glow lamp." It is a glass enclosure with a wire brought out from each of two electrodes, and the enclosure is filled with Neon gas and sealed. When a DC voltage is applied the Neon gas will glow at the Negative electrode. Also, the video below shows (at 9:06) how to get a Wimshurst "started" or "charged", this approach may enable you to set the desired polarity.
NEON TESTER
157 000 hits found with: https://www.google.com/search?&q=wimshurst+machine
A rather detailed explanation:
Cheers,
Tom
  • images?q=tbn:ANd9GcSKwU0KVbaMdcU2Jn3hLLkY4CSOX30GbxfaMF4KCUjvljlYcwxGww.jpg
Hello
What is Corona how it work
Hello
How to watch corona in real life on wire
RITESHH KAKKAR said:
Hello
That's a very good question. If you have a high voltage (such as 500KV) power transmission line near you, go out on a dark night and watch.
Also, search for "corona discharge" on Youtube. There are several videos.
Likes berkeman
Hello
Is it seen by Camera or simple eyes
