How to solve a Sum of Forces Problem with Two Springs and Varied Masses?
  • Thread starter Thread starter simplemail1
    Forces Sum
The problem involves two springs with crates of varying masses. The first part requires determining the compression of a spring with a combined mass of 8 kg, its oscillation frequency, and maximum amplitude after contact. The second part involves a different spring with two boxes stacked, focusing on maximum horizontal acceleration and amplitude without slipping. The spring constant is given as 1000 N/m, but specific numerical values for some variables are not provided.
  • Mixed
  • Participants discuss using the sum of forces and Newton's second law to analyze the first spring's behavior. Some suggest considering conservation of energy as an alternative approach. There is also mention of the need to differentiate between the spring's equilibrium position and its natural length. For the second spring, the role of friction is highlighted, and questions arise regarding the clarity of the problem statement and the completeness of the information provided.
Participants are exploring various methods to approach the problem, with some providing guidance on applying Newton's equations and discussing the implications of gravitational forces versus friction. There is an acknowledgment of potential ambiguities in the problem statement, prompting suggestions for clarification.
Some participants note that the original poster may not have included all details from the problem statement, which could affect the interpretation and approach to the questions posed.
simplemail1
1. The problem statement, all variables and given/known
There is a spring with two crates, (5kg +3 kg) as shown in this picture. (1)
The spring constant is 1000 n/m.
I need to find
a) How much the spring is compressed from its initial position (at rest)
b) The frequency of the oscillation
c) Max amplitude after contact
And then there is a different spring, oscillating horizontally with 2 boxes on top of each other, m1 on m2. The maximum force of friction is define as f.
I need to find the a) max horizontal acceleration for the m1 not to slip on m2 and I need to find the b) max amplitude for simple harmonic motion without m1 slipping. I'm not given any numbers whatsoever.
For a) I would think I would do (8)(9.8) and then do that against the force of the constant
b) I think I would use w (frequency?) = (k/m)^1/2.
c) I'm not too sure on this
I don't know what to do afterwards (or at all) for the second spring
Any advice to kick me off?
Hi simplemail1,
For part a of the first problem, you can definitely use the sum of the forces; however, the acceleration is not zero so you would need to be able to tell what the acceleration is and set the sum of the forces equal to [itex]ma[/itex]. As an alternative, I would try using conservation of energy to find the answer.
Hi,
Exactly, all of these questions can be solved from the Newton's equation F=ma.
a) In this case, the equilibrium position is asked, so a=0 and sum of forces=0. In the sum of forces, you have the gravitation force mg and the reaction of the spring k(l-l0). In those kind of problems always be aware of the difference between the position at rest and the natural length of the spring l0 that are different due to the gravitation
b) F=ma allows you to obtain the differential equation of movement, mx''+kx=0 so you can have the pulsation
c) solving the differential equation allows you to have x(t), x'(t) and x''(t), which all will be sinusoidal functions... It is easy to have their maximum
For the second spring, always the same problem, but the forces will be different: no gravitation, but friction force.
Hi jonpoux,
jonpoux said:
Hi,
The wording of the question is not too clear, but I don't think they are asking for the equilibrium position in this problem. They are setting up an oscillation so I think they want the maximum distance the spring is compressed from it's initial position during the oscillation.
simplemail,
It doesn't look like you typed in the complete statement of the problem. It might be best if you type in everything the problem said; little details can make a big difference.
  • · Replies 16 ·
