How to Solve for atan when an object turns 60 degrees
  • Thread starter Thread starter TamuNinja
    Degrees
To compute the tangential acceleration (atan) of a flywheel after it has turned 60 degrees, the formula atan = α * radius is used, where α is the angular acceleration. Given that the flywheel has a radius of 0.200 meters and an angular acceleration of 0.900 rad/s², the tangential acceleration remains constant at 0.180 m/s², regardless of the angle turned. The initial confusion about needing to account for the distance moved was resolved, confirming that atan is solely dependent on the angular acceleration and radius. Thus, the tangential acceleration at 60 degrees is 0.180 m/s².
TamuNinja
A flywheel with a radius of 0.200 starts from rest and accelerates with a constant angular acceleration of 0.900 .
atan= .180 m/s2 when its at rest
arad= 0m/s2 when at rest
compute magnitude of resultant acceleration at the start a= .180 m/s2
I got all of these already now the question is
Compute the magnitude of the tangential acceleration of a point on its rim after it has turned through 60.0?
atan= ? m/s2
The attempt at a solution
I do not know how to answer this. I honeslty don't know where to start.
I know atan= \alpha*radius but i don't know what to do now that the flywheel is turning 60
Solved it.
Turned out that i didnt need to worry about how far it moved so it was just Alpha*radius
Giving me atan=.180m/s^2
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
