How to support a sign on our museum wall?
To support a 12-foot triangular sign weighing 200 pounds on a museum wall, two guy wires anchored 12 feet apart at a 45-degree angle are recommended. Each wire will bear approximately 150 pounds of load, so selecting stainless steel cable with a diameter of at least 4mm (or 3/16") is advisable for safety. It's important to consider the yield strength of the cable and potential adverse weather conditions, which may require stronger materials. Overestimating cable strength is prudent to ensure reliability and safety. Using a thicker cable can prevent failures at anchor points or welds before the cable itself gives way.
agap015
Hi all,
I went to an engineering school 40 years ago but never finished, so I kind of know that this is easily solveable.
I have a triangular sign 12' long (attached to wall) that is 2 1/2' thick and sticks out from the wall 6'. If I use 2 guy wires anchored to the wall 12' apart, that meet the sign at a 45* angle at the point, how large should the wires (stainless steel cable) be in diameter?
The sign weighs 200# total.
The sign is to be attached to our local museum announcing an event.
Thanks
George
I'm a physicist, but pretty far removed from engineering, so take it for what it's worth. Hopefully, somebody better qualified will come along.
If I understand your setup correctly, each wire is under roughly 150lb of load. (A diagram would help to make sure.) You want this to be within yield strength for the wire, to give yourself a bit of an overhead. Of course, there are steel cables, and then there are steel cables. But you should be able to count on at least 200MPa. That means wire just a touch over 2mm in diameter. So you should go with at least 11 gauge (AWG) for this.
Keeping the load within yield strength should make the structure reliable enough, and if things go wrong, should be able to take nearly twice as much load for a short while. But if you expect adverse weather, such as winds or snows, you'd have to account for that separately.
Thanks for the reply.
2MM isn't very large. I will probably use 3/16" cable or about 4MM. The sign is a half scale theater marque. It will showcase our town theater.
Thanks
George
I am also an owner of a Museum.
I agree with K^2 that it is simply prudent to "overestimate" on the side of safety in supporting this marque. What's the difference in cost or difficulty of using a "stronger than you think is mimimally necessary cable"?
Bobbywhy
4mm really ought to do it. I'd expect anchor points or welds on the marquee to go before a 4mm cable does.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
