How to use wolfram alpha to plot frequency response
To plot the magnitude and phase response of the transfer function H(s) on Wolfram Alpha, users can utilize the functions abs(...) and phase(...) with the imaginary unit i. For phase plotting in degrees, the 'bode(...)' function is recommended, which also provides additional plots like Nyquist and Nichols. Users expressed appreciation for the guidance, noting its practical application. There is a learning curve for understanding concepts like Nyquist and Nichols, but the tools provided are seen as beneficial. Overall, the discussion highlights effective methods for frequency response analysis without Matlab.
Void Xylem
Can someone please tell me how I can plot the magnitude and phase response of this transfer function on wolfram alpha as I don't have Matlab:
H(s) = -(2.1953*10^12)/(66600*((j*ω)^2)+808823539.4*(j*ω)+2.1626*10^12)
A link to the output would be very useful also, thanks heaps.
You can use abs(...) and phase(...) with i as the imaginary unit.
thanks bro, your post has improved my life quality by a factor of 0.0001, one more question: How do I make it plot the phase in degrees instead of radians.
You can also use 'bode (...)', which will plot the amplitude and phase in degrees. As a bonus you get Nyquist and Nichols too :)
haha wow that's really cool, its going to be very useful, i got to admit i have no idea what the Nyquist and Nichols are atm but ill get there eventually. thanks for the help.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
