How would one connect three 9Ω resistors to get 12Ω?
  • Thread starter Thread starter bpani
    Resistors
To achieve a total resistance of 12Ω using three 9Ω resistors, one must consider both series and parallel configurations. The discussion highlights that standard connections do not yield the desired resistance, suggesting a more complex approach may be necessary. A hint is provided indicating that cutting the resistors in half could be a viable solution. The problem appears in a textbook, implying that a solution exists, but the exact method remains unclear. Overall, the conversation emphasizes the challenge of connecting these resistors to reach the specified resistance.
bpani
how would one connect three 9Ω resistors to get 12Ω??
Statement
equations
i guess the relevant equations would be nothing more than series & parallel resistance connections..
The attempt at a solution
I've tried all possible ways to connect them (only 4 diff ways I guess??). There is apparently a solution since its in my nephew's textbook.
bpani said:
Statement
equations
Hint -- you are going to have to cut the resistors in half with a fine saw...
I can do it with 4. Are you sure you read the problem correctly?
But I like Berkeman's answer better.
12K
