Hp vs rpm to displacement vs time graph?
To create a displacement vs time graph for the motorcycles, calculate the acceleration at each 1/10 second interval using the derived acceleration values based on horsepower, mass, gear ratio, and tire circumference. Then, update the velocity by adding the acceleration contribution to the previous velocity at each interval. Starting from an initial speed of 0 m/s, you can plot the velocity over time to visualize how it changes. Finally, integrate the velocity data over time to obtain the displacement values, which can then be plotted against time. This method will allow for an accurate representation of displacement over time for the motorcycles.
Drillbit
Hello, I am a high school student trying to compare two motorcycles on a displacement vs time graph.
The information I have is the mass of riders, mass of bikes, gear ratios, tyre circumference and dyno results indicating hp vs rpm. I am not taking air/rolling resistance into consideration and the run should start in first gear and use optimal shift points.
What I've done so far is to create a acceleration(derived from hp, mass, gear ratio and tyre circumference) vs velocity(derived from rpm, gear ratio and tyre circumference) graph of the bikes for each gear. Plotted on one graph this shows me the optimal shift points(the points where the graphs overlap). I can also create a displacement vs velocity graph but can't think of how to relate this to a displacement vs time graph? General instructions will be much appreciated.
Take 1/10 second intervals.
The initial speed is 0m/s.
You need to figure out the acceleration rate at each 1/10 second interval, then add it's contribution to the velocity at the previous point.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
