Humidity definitions and measurement devices
Humidity is defined in three ways: absolute, relative, and specific. Commercial devices, like those found in clocks, typically measure relative humidity (RH) as a percentage, indicating the ratio of current water vapor to the maximum possible at a given temperature. Percentages of relative humidity cannot exceed 100%, as this would indicate saturation, often leading to precipitation in non-tropical climates. In tropical regions, relative humidity can reach 95-100% without rain, creating uncomfortable conditions. The measurement of humidity is influenced by air temperature and pressure, highlighting the significant capacity of air to hold moisture.
Delta2
Insights Author
I know there are three definitions of humidity. Absolute , relative and specific. Can you tell me if on a typical commercial device (such as the one i have in a clock i have) that measures humidity as percentage is it the relative humidity that it measures? Can the percentage become greater than 100%?
When measured as a percentage, its a reference to RH - relative humidity its measuring the relative difference between absolute humidity ( actual water content) and the maximum water content that the air can have at a given temperature
not that I have ever seen or heard of
... in non tropical climates, 100% would usually mean its raining. In tropical climates, I have often seen 95 - 100% and still not raining, but ohhhh gosh, the air is just so unbearable and "sticky"
Air temperature and pressure have a large bearing on this
It never ceases to amaze me how much moisture the air can hold as invisible vapour
Dave
More precisely, it's the ratio of the water vapor partial pressure in the air to the equilibrium vapor pressure of water at the air temperature.
Chet
Likes davenn
LOL yup ... didn't want to go too deep :wink:
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
