How much time will it take for a log to arrive from point A, to point B?
  • Thread starter Thread starter HellgY
    Log Point Time
The discussion revolves around calculating the time it takes for a log to float from point A to point B on a river, given that a boat takes 5 hours to travel downstream and 7 hours to return upstream. The participants analyze the impact of the river's flow on the boat's speed, suggesting that the flow speed (V0) is a key variable in the calculations. They propose equations to relate the times and speeds but express confusion over the correct formulation and solution. Clarifications about the direction of the flow and the need for additional information, such as the boat's velocity, are also mentioned. The focus remains on determining the log's travel time based on the established parameters.
HellgY
A boat floats across this river, and back,
It takes 5 hours for it to reach point B, from point A, and then 7 hours to
return to point to point A from point B.
Naturally it's because not because the crew got tired on the way back,
but because the flow of the river, or it's angle which is pretty much more of the same.
the question is: How much time will it take for a log to arrive from point A, to point B?.
I believe the V0=Constant(The flow), otherwise that teacher would have said mentioned it.
i believe the equation is:
T2/V1=T1/V1-V0
The equation with all the numbers intact should look like that:
7/x=5/x-y
and there is another equation i can add, based upon the fact that the distances AB, and BA are the same.
T1*V1=T2*(V1-V0)
5x=7x-7y
does anyone have a clue how can i sole this correctly?, because my solution just doesn't seems correct at all.
{7/x=5/x-y
{5x=7x-7y*
or is it:
{5x=7x-yx
{x-y=5x/7*
Welcome to the Forums,
Let me see if I've got this question straight in my head. A boat starts from point A to B, this takes five hours. Then the boat turns around and floats back to point A under no propulsion. You need to know how long it will take a log to float from A to B?
Have I got that about right? Is there a diagram?
It floats 7 hours back, with propulsion, apparently against the flow, or the angle of the river, or any constant force for that matter.
i need to calculate how quickly will a block of wood arrive from point A, to point B, driven by the flow of the river obviously, so what i need to find is V0, which is the speed of the river flow
Do you have the velocity of the boat? Width of the river? I diagram would be very useful here. I am assuming that point A is downstream from point B.
It's the other way around, point B, is a downstream from point A.
I don't have the Velocity of the boat, Just the info i provided.
I'm suppose to find V1 and V0 with an equation, it isn't supposed to be a problem since we are dealing with constant speeds here
