Hydraulics for Landing Assemblies?
  • Thread starter Thread starter Arctic Fox
    Hydraulics
Information on hydraulic parts and pumps for designing landing assemblies can be found by searching "Hydraulics for Landing Gear," which yields numerous resources. Visual aids and purchasing links for large hydraulic components are available through this refined search. The discussion highlights the importance of keyword specificity in online searches to access relevant data. Participants express encouragement for the project, emphasizing the value of community support. Utilizing targeted search terms significantly enhances the discovery of useful information.
Arctic Fox
Where can I find information on hydraulic parts/pumps in order to design my own landing assemblies?
I'd like to see how one works in heavy aerocraft. Pictures and also links to places where I can purchase large parts, etc.
Try switching your search to "Hydraulics for Landing Gear" Google seems to several leads for you.
Wow. Change one word in a search, now all sorts of information comes up. :bugeye:
Thanks!
Your welcome. hope your project goes well for you.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
