Hydrogen atom - small perturbation
In summary, the conversation discusses finding first-order perturbation corrections and exact levels for a hydrogen atom perturbed by a potential. The attempt at a solution suggests using a new parameter k to find the exact levels, but there is uncertainty about whether k needs to be an integer. Further research into time-independent perturbation theory is recommended.
neworder1
66
A hydrogen atom is perturbed with the potential [tex]V(r) = \frac{\alpha}{r^{2}}[/tex] ([tex]\alpha[/tex] is small). Find first-order perturbation corrections to the energy levels and then exact levels of the perturbed system.
The unperturbed hydrogen atom radial equation is:
[tex]-\frac{\hbar^{2}}{2m} \frac{d^{2}u}{dr^{2}} + [-\frac{e^{2}}{4\pi \epsilon_{0}} \frac{1}{r} + \frac{\hbar^{2}}{2m} \frac{l(l+1)}{r^{2}}]u = Eu[/tex]
where [tex]l[/tex] is an integer.
I don't know how to find the exact energy levels of the perturbed system. Because the perturbation is proportional to [tex]\frac{1}{r^{2}}[/tex], in the radial equation for the perturbed atom I can introduce a new parameter [tex]k[/tex] such that:
[tex]\frac{\hbar^{2}}{2m} \frac{k(k+1)}{r^{2}} = \frac{\hbar^{2}}{2m} \frac{l(l+1)}{r^{2}} + \frac{\alpha}{r^{2}}[/tex].
Then new energy levels will be just energy levels of an unperturbed hydrogen atoms with [tex]k[/tex] in place of [tex]l[/tex]. But then, [tex]k[/tex] has to be an integer for the hydrogen solutions to make sense, and it is at the same time a function of the parameter [tex]\alpha[/tex], so it need not be an integer. What's wrong here? How to find the exact energy levels?
It looks like your attempt at a solution is trying to find the exact levels. Take a look at Chapter 6 in Griffiths' QM book for finding the first-order perturbation corrections. You could probably also look up time-independent perturbation theory on the web and find a wikipedia page or something.
I'm not completely sure about finding the exact levels, but I think you have a good idea there. This perturbation won't affect the spherical harmonics at all since it is r-dependent. It seems like it might work to just replace [tex]n=j_{max}+l+1[/tex] with [tex]n=j_{max}+k+1[/tex] and plug the n into the energy formula, but I'm not so sure there because of the issue of k not having to be an integer.
1. What is a "small perturbation" in relation to a hydrogen atom?
A small perturbation in a hydrogen atom refers to a small disturbance or change in the atom's energy, caused by an external force or interaction. This perturbation can cause the atom to transition to a different energy state, known as a perturbed state.
2. How does a small perturbation affect the energy levels of a hydrogen atom?
A small perturbation can cause the energy levels of a hydrogen atom to split, resulting in multiple energy levels instead of the usual single energy level. This splitting is known as the Stark effect, and it can be observed in the atom's emission or absorption spectrum.
3. Can small perturbations have a significant impact on the behavior of a hydrogen atom?
Yes, small perturbations can have a significant impact on the behavior of a hydrogen atom. For example, they can cause the atom's energy levels to shift, change the atom's emission or absorption spectrum, and alter the atom's overall behavior and properties.
4. What are some common sources of small perturbations in a hydrogen atom?
Some common sources of small perturbations in a hydrogen atom include external electric or magnetic fields, collisions with other particles, and interactions with photons or other electromagnetic radiation.
5. How do scientists study small perturbations in hydrogen atoms?
Scientists study small perturbations in hydrogen atoms through various experimental techniques, such as spectroscopy, where the atom's emission or absorption spectrum is measured. They also use theoretical models and calculations to understand the effects of different perturbations on the atom's energy levels and behavior.
