Hydrogen to Helium Helium to heavier elements
The discussion centers on the process of nuclear fusion in stars, explaining how hydrogen combines to form helium and subsequently leads to the creation of heavier elements. Initially, hydrogen atoms fuse under extreme temperatures and pressures in stars, primarily through the proton-proton (PP) chain reaction, producing helium. As helium accumulates, it can undergo further fusion, particularly in more massive stars through the carbon-nitrogen-oxygen (CNO) cycle, which also contributes to energy production. The conversation highlights the role of deuterium, a hydrogen isotope, in the fusion process, noting that while helium fusion can be unstable, deuterium serves as a crucial intermediary in forming heavier elements. The discussion also touches on the aftermath of supernova explosions, which can facilitate the fusion of even heavier elements due to the extreme conditions created. Overall, the thread seeks to clarify the steps from hydrogen to helium and then to heavier elements, emphasizing the complexity and significance of these nuclear processes in stellar evolution.
p.falk
Would someone mind (in simple terms if possible) explaining how at the beginning of the universe Hydrogen combined to give Helium; then then how Helium combined with deuterium to create the heavier elements?
I would just like to be more versed on this process...
Thanks for any help!
Chemistry news on Phys.org
Short answer: stars "burn" via nuclear fusion. Hydrogen atoms combine to form helium. As helium concentrations get higher, helium atoms fuse to form heavier elements. If the star goes supernova, the resulting explosion is powerful enough for endothermic fusion of heavier elements into really heavy elements.
But I thought a Helium can't combine with another Helium atom because the result would be too unstable. If a Helium(2 protons/2neutrons) combines with a Helium you have 8 particles... but atoms with 5 or 8 particles are unstable.
That's why I wanted to know what role deuterium plays in this...
How is deuterium created? How long does it last on it's own? What are the steps from Hydrogen to Helium to heavier elements?
I appreciate your response russ_watters, I guess I would like some more detail with it though.
Thanks for helping...
The sun produces energy primarily by the PP reaction and about 1-2% by the CNO cycle. The CNO cycle occurs in more massive stars -
http://csep10.phys.utk.edu/astr162/lect/energy/cno-pp.html
http://burro.astr.cwru.edu/Academics/Astr221/StarPhys/ppchain.html
http://csep10.phys.utk.edu/astr162/lect/energy/cno.html - for CNO discussion
In addition to H and He, there are quantities of Li, Be and B, and they will be producing their emission spectra as well.
See also - http://www-phys.llnl.gov/Research/RRSN/
and
Helium Burning in Stars
In the second link above, one will find
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
