Hydrostatic Problem: Hinged water gate at the bottom of a reservoir
The discussion revolves around a hydrostatic problem involving a hinged water gate at the bottom of a reservoir. The calculations for the force acting on the gate and the moment due to water pressure were initially thought to be correct, with the force calculated as 19,405 N and the moment as 10,977 Nm. However, a discrepancy arose in part c, where the calculated mass Q needed to balance the moments was found to be 1,398 kg, while the expected value was 1,527 kg. The error was identified in part b, where the moment calculation did not account for the pressure distribution along the gate, necessitating an integration approach. The discussion concludes with the realization that proper integration over the gate's length is essential for accurate results.
CWatters
Homework Helper
See Below
F = ρgAd
My son and I are having a problem with part c that suggests our answer for part a and b are wrong..
Part a). If we've understood the teaching notes correctly the force on the gate acting through its centroid perpendicular to the gate and is given by
F = ρgAd
where
ρ is the density of water 997 kg/m^3
g is 9.81m/s^2
A is the area of the gate
d is the depth of the centroid of the gate
The area of the gate A is
A = 1.1 * 0.8/cos(45)
= 1.24 sqm
The centroid is half way up the gate so at a depth d below the surface of
d = 2-0.4
= 1.6m
So the Force F acting through the centroid is
F = 997 * 9.81 * 1.24 * 1.6
= 19,405 N
Part b) The centroid of the gate is at..
y = 0.5 * 0.8/cos(45)
so the moment M acting on the gate due to water pressure is
M = 19,405 * 0.5 * 0.8/cos(45)
= 10,977 Nm
Part c) If the gate isn't accelerating the net moment must be zero.
The clockwise moment due to the mass Q is
= 0.8*Q*g
The anti clockwise moment due to water pressure is 10,977 Nm from above.
Equating these gives
0.8*Q*g = 10,977
and
Q = 10,977/(0.8*g)
= 1,398 kg
So we have failed to prove mass Q needs to be 1,527 kg
Where are we going wrong?
[edit]misfired :)
I think part b may not have been done right. If the pressure at y is p(y). the moment of the pressure force is $$M=\int{wyp(y)dy}$$This would not be equal to the force times the distance to the centroid.
Thanks Chester! That was the problem. Looking back at his notes confirms you need to integrate over the length of the gate to get the net force and moment. He's written it up in the attached MSword doc.
Likes Chestermiller
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
