Hyperbola in Cartesian Planes problem
kasse
Does the plane that intersects the cone need to be parallell to the axis of the cone to make the section a hyperbola, or is it enough that it is not parallell to a generator?
If the latter is correct, can one say that a parabola is a special case of a hyperbola?
The Latter is correct.
The hyperbola in Cartesian Planes is defined by Ax^2 + Bxy + Cy^2 + Dx + Ey + F = 0. As you Can see, a parabola is simply where B and C equals zero.
Thank you!
No problemo :)
If one takes one of the focal points of a hyperbola to infinity, then the remaining curve would be a parabola. Same is valid for an ellipse.
In other words let b tend to infinity in
\frac{x^{2}}{a^{2}}\pm \frac{y^{2}}{b^{2}} =1
and you'll get a parabola.
Daniel.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
