I have been working on this problem for HOURS PLease helpe me
  • Thread starter Thread starter BuBbLeS01
The problem involves calculating the magnification of a telescope with a focal length of 200 cm for the objective and 1 cm for the eyepiece. The user initially calculated the magnification using the formula M = Fo/Fe, resulting in 200, but the expected answer is 20. The confusion arises from the fact that when viewing an object at infinity, the correct formula for magnification is M = Fo/Fe, but it must also account for the distance at which the eyepiece focuses light. The key takeaway is that the magnification is influenced by the effective focal lengths and the viewing distance, leading to the correct answer of 20. Understanding the relationship between focal lengths and object distance is crucial for accurate calculations in optics.
BuBbLeS01
I have been working on this problem for HOURS! PLease helpe me!
The objective of a telescope has a focal length of 200 cm and its eye piece has a focal length of 1 cm. What is the magnification of this telescope when viewing an object at infinity??
I thought ...
M = Fo/Fe which would = 200 but the answer is 20! Why? Does infinity have something to do with it??
Anyone know about this??
