I have to design accumulator of energy
The discussion focuses on designing an energy accumulator using an insulated cylindrical tank filled with water. Key concerns include calculating heat losses, considering convection between the water and the tank wall, and understanding conduction through the tank's structure. The complexity increases with the tank's multiple sides, and there's a suggestion that a single wall design might simplify calculations. Participants emphasize the need for specific details about the tank's construction and the temperatures involved to provide accurate guidance. Overall, clarity on these factors is essential for effective design and analysis.
patrycja
I have to design accumulator of energy. Let's consider insulated cylindrical tank with water. How to calculate all heat losses. Should i consider convection between water and wall and then conduction? but what with all sides of tank? It would be easier with single wall. how to get all coefficients? I will really appreciate any help
Welcome to PF!
You'll have to be more specific about the construction of the tank and temperatures involved.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
