How High is the Apartment House from Which Balloons Were Dropped?
  • Thread starter Thread starter Palmtree Panic
    Physics
To determine the height of the apartment house from which the balloons were dropped, the problem involves calculating the time it takes for both balloons to hit the ground, considering one is dropped and the other is thrown downward with an initial speed. The acceleration due to gravity is given as 9.8 m/s². The first balloon is released from rest, while the second is thrown 3.8 seconds later. Participants in the discussion emphasize the need to apply kinematic equations to solve for height, and there is a reiteration that the forum is not a homework service but a platform for guidance. The final answer requires proper application of physics principles to derive the height in meters.
Palmtree Panic
You and your friend throw balloons ¯lled with
water from the roof of a several story apart-
ment house. You simply drop a balloon from
rest. A second balloon is thrown downward
by your friend 3:8 s later with an initial speed
of 74:48 m=s. They hit the ground simultane-
ously.
The acceleration of gravity is 9:8 m=s2 : You
can neglect air resistance.
How high is the apartment house? Answer
in units of m.
idk
too many wrong attempts
Show us one, so we can see what you're thinking.
Or you could just give me the answer.
No, I can't. That's against forum rules. We aren't a homework service. You must do the work, we can only guide you.
I do not know what equation to use. Can someone help me with that?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
