Force Applied by 0.145kg Baseball to Catcher's Mitt
  • Thread starter Thread starter smbascug
To calculate the average force applied by a 0.145-kg baseball traveling at 35.0 m/s when it strikes a catcher's mitt and brings the ball to rest while recoiling 11.0 cm, one can use the work-energy theorem. The change in kinetic energy equals the average force multiplied by the distance over which it acts. Additionally, the impulse-momentum theorem can also be applied, where the change in momentum equals the average force times the time duration of the impact. Both methods provide a way to determine the average force exerted by the baseball on the glove. Understanding these principles is essential for solving similar physics problems.
smbascug
A 0.145-kg baseball traveling 35.0 m/s strikes the catcher's mitt which, in bring the ball to rest, recoils backward 11.0 cm. What was the average force applied by the ball on the glove?
Can someone show me a formula for this problem or a way to solve this problem?? Please and Thank You
In this example, you may use that the change of kinetic energy is equal to the average force times the distance over which the force acts (this is a special case of the work energy theorem, It is that simple here because no other force does any work. For example gravity does not do any work because the height of the baseball does not change)
Patrick
Another way, and a good practice: Whenever you see the term "average force" think of the impulse-momentum theorem: m \Delta v = \bar F \Delta t.
-Dan
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
