I programming in Chipmunk Basic with arrow keys, and random coordinate gen.
The discussion centers on programming a game in Chipmunk Basic, specifically using the arrow keys and spacebar for controls. The user is attempting to create a simplified version of the snake game, where a line moves around the screen to collect colored dots. They express difficulty in implementing controls for the arrow keys and inquire about creating graphics and sprites in Chipmunk Basic, noting its differences from other Basic software. A suggested approach involves using the inkey$ function to detect key presses, with instructions to test the output of pressing various keys. The user also mentions encountering a type mismatch error and provides a link for further clarification on their issue. Overall, the thread focuses on troubleshooting input handling and graphics creation in Chipmunk Basic for game development.
CharlieO1212
I am trying to make a game in Chipmunk Basic using the arrow keys but I can't because I cannot figure out how. I have programmed in other Basic Softwares but I cannot figure out how to use the arrow keys and spacebar in my programs. An example (much simplified) of a game I am making is snake (if you don't know what it is its where a line goes around the screen and you need to come into contact with colored dots to make your "snake" bigger. If you run into yourself then the game ends). IF you know how to make graphics/sprites with colors in CB (Chipmunk Basic) then please let me know because CB is a lot different with graphics than other programs.
Technology news on Phys.org
Can you make this work?
while
s=inkey$
if s<>"" then print asc(s)
wend
Test that by gently pressing a single key, like X or 3.
If that works then gently press one arrow key and post the results.
For X it should print a single number.
For an arrow key it may print 1 or 2 or 3 or 4 lines of single numbers.
If that works then you need to build a little machine in software that uses the numbers.
It gave me a type mismatch error in line 20
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
I am trying to run an .ipynb file and have installed Miniconda as well as created an environment as such -conda create -n <env_name> python=3.7 ipykernel jupyter I am assuming this is successful as I can activate this environment via the anaconda prompt and following command -conda activate <env_name> Then I downloaded and installed VS code and I am trying to edit an .ipynb file. I want to select a kernel, via VS Code but when I press the button on the upper right corner I am greeted...
