I think i did this electric potential problem correctly but
A helium nucleus with a charge of +2e and mass of 6.63E-27 kg enters an electric field, moving from a potential of 1.5E3 V to 4.0E3 V. The attempt to calculate the speed at point B using the equation delta V = - (delta KE)/q led to an incorrect final speed of 7.91E5 m/s, while the expected answer is 3.78E5 m/s. The mistake identified is a sign error, as the nucleus moves from a lower to a higher potential, indicating it should slow down rather than speed up. The discussion emphasizes the importance of correctly interpreting the direction of electric fields and potential differences in such problems. Understanding these concepts is crucial for accurately solving electric potential problems.
punktux
a helium nucleus (charge =2e, mass = 6.63E-27 kg) traveling at a speed of 6.20E5 m/s enters an electric field, traveling from point A, at a potential of 1.5E3 V, to point B, at 4.0E3 V. what is the speed at point B?
charge = 2e = 2 * 1.6E-19 C
delta V is potential difference.
i used equation delta V = - (delta KE)/q and derived the relationship:
delta V = - mass/2q (vf^2 - vi^2)
since the charge is 2e and e for electron is -1.6E-19 C, so the right hand side is positive. the left side is 4.0E3-1.5E3...finally i solved vf and got 7.91E5 m/s but the answer is 3.78E5 m/s
i don't get it...where is the mistake?
I think you are making a sign error. Electric fields point from higher potential to lower potential. The helium nucleus is +2e (not a negative charge). This positive charge is going from A to B, or lower potential to higher potential. This means it is going against the E field. This means that the nucleus will slow down, not speed up. Notice that the answer you want is smaller than the initial velocity.
Note: I haven't done the math to check your equations. I'm just looking at what the answer, in general, should look like.
