The discussion revolves around the construction and operation of a flyback converter using lithium-ion batteries, specifically addressing issues related to current capacity and battery overload. Participants explore the feasibility of passing 3.5 amps through the converter without damaging the batteries, while discussing circuit design elements such as the inclusion of switches, diodes, and capacitors.
- Technical explanation
- Debate/contested
- Exploratory
- One participant reports connecting a flyback converter to three 18650 lithium-ion cells and experiencing battery damage when attempting to draw 3.5 amps.
- Another participant suggests that the absence of critical components like a switch and PWM control may be contributing to the issues faced.
- There are inquiries about using non-rechargeable batteries and connecting batteries in parallel to manage current draw.
- Participants discuss the importance of understanding battery specifications, such as maximum discharge rates and capacity, to avoid overload.
- One participant provides detailed specifications for a specific 18650 battery model, indicating a maximum constant current of 20A, suggesting that 3.5A should not overload the batteries if properly configured.
- Another participant proposes two theoretical methods to safely draw more current: using batteries in parallel with protective measures or using batteries in series with a stepping down converter.
- There is a suggestion to integrate a current reduction function into the existing flyback converter design rather than switching to a separate step-down converter.
- Concerns are raised about the safety and practicality of using batteries in parallel for DIY projects.
Participants express differing views on the best approach to safely draw 3.5 amps from the circuit, with some advocating for parallel connections and others cautioning against them. The discussion remains unresolved regarding the optimal configuration and safety measures needed.
Participants highlight the need for a better understanding of battery specifications and circuit design. There are mentions of missing components in the initial schematic that could affect performance and safety.
This discussion may be useful for individuals interested in electronics, particularly those exploring power supply designs, battery management, and flyback converter applications.
