Find IC Packages: Database & Drawings | Solved
  • Thread starter Thread starter Jdo300
    Database Ic
A user inquired about a database for browsing IC package types and their dimensioned drawings, expressing frustration with individual datasheets. Another participant highlighted that while package types are generally standardized, most manufacturers do not provide mechanical drawings online. A helpful resource was shared that includes images and links to PDF package outline drawings for common IC packages. Caution was advised regarding the potential discrepancies in package specifications, emphasizing the importance of verifying datasheet dimensions to avoid costly mistakes. The discussion underscores the need for reliable resources and careful verification in IC package selection.
Jdo300
[SOLVED] IC Package Database?
Hello All,
Does anyone know if there is a website somewhere where you can browse a database of IC package types and see dimensioned drawings for them? I see lots of different options out there for the many ICs and transistors but it gets annoying when you have to browse the individual data sheets in order to see what the packages look like.
- Jason O
The package types are industry standards -- one company's SOT-23 is the same as another's for example. Most semi companies have archives of package mechanical drawings, but they don't usually put them on the web. I don't personally know of any database.
- Warren
Speaking from painful experience, I'd check the datasheet for the part...
I specified one part that was "SSOP" which turned out to mean something very different from what I expected... the common or garden SSOP package data that I gave the pcb guy was 25 thou pitch, whereas the actual part was metric with 1mm pitch. I was ever so pleased.
On the rerun, he gave it a 50 thou pitch, which just about useful with a careful bit of bending of the leadouts...
On the third attempt we got it right.
yes be very careful of going with the "industry standard" for package names, you might be ok most of the time, but not always. Always double check the datasheet, I almost fell into this trap a few times as an intern and was lucky that I was paranoid enough to actually look at the datasheet dimensions and see it differ from the industry standard recommendations.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
