Efficiently Manufacture 3.0kg of Ice Cubes: Calculating Minimum Work
  • Thread starter Thread starter CartoonKid
    Ice Manufacturing
The discussion revolves around calculating the minimum work required to manufacture 3.0 kg of ice cubes from water at 0°C, with surrounding temperatures at 30°C. Participants debate the correct calculation methods, with initial estimates of work ranging from 100.6 kJ to 117.1 kJ. The efficiency of the process is calculated using the Carnot efficiency formula, leading to different interpretations of the input and output values. A consensus emerges that the correct approach involves using the coefficient of performance (COP) to determine the work needed, resulting in an updated figure of approximately 111.7 kJ. The conversation highlights the complexities of thermodynamic calculations in ice manufacturing.
CartoonKid
Calculate the minimum work required to manufacture 3.0kg of ice cubes from water initially at 0C. Assume that the surroundings are at 30C. The latent heat of fusion of water at 0C is 338.7kJ/kg.
My working:
e=1-\frac{273}{303}
then
e=\frac{work}{input}
input=(3.0)(338.7E3)
work=100.6kJ
But I saw the other answer from someone that it is 117.1kJ. Which one is the correct answer? Is my answer correct? If not, please rectify for me. Thanks.
First of all efficiency=1-T2/T1*100%=1-273/303*100%=9.9%
Then efficiency=usefuloutput/Inputbythemachine=(3*338700)/input
So
work needed as I calculated is 102.64KJ AND you are both wrong (if I am not wrong...)
Thats because what you have to calculate is the input the machine needs since it has the given efficiency to make it out to create ice cubes or whatever...
Now I have got the way of how the other answer was being worked out.
COP=\frac{Q_{cold}}{Work}
COP=\frac{T_{cold}}{T_{hot}-T_{cold}}
After sub in all the values,
Work=\frac{(3.0)(338.7E3)}{9.1}
and the answer appears to be 111.7kJ (sorry, typo error in the first post)
ColdRifle, I don't understand why you sub in (3.0)(338.7E3) as your usefuloutput. Isn't that eff=work/input for carnot cycle?
