The Meaning of the Ideal Gas Equation: Vdp + pdV = 0
  • Thread starter Thread starter quietrain
    Gas Ideal gas
When temperature is constant in the ideal gas equation, the relationship Vdp + pdV = 0 indicates that the product PV remains constant. This is derived from the derivative of the constant PV, leading to the expression P(dV/dx) + V(dP/dx) = 0. The discussion highlights that pdV represents work done by the gas, while VdP relates to energy gained through heat flow, emphasizing the balance of energy in a closed system. The equation can also be manipulated to derive compressibility, though it is not strictly necessary for that purpose. Ultimately, the equation illustrates the principle that energy lost through work must equal energy gained through heat to maintain constant internal energy.
quietrain
PV = nRT
why when T is constant,
Vdp + pdV = 0?
If T = const., then PV = const.
If we take the derivative of both sides with respect to "x" (which is any relevant variable), we obtain:
\frac{d}{dx}(PV) = 0
where the right hand side is zero because the derivative of a constant is zero. Now, the product rule from differential calculus says that the left-hand side becomes:
P \frac {dV}{dx} + V\frac{dP}{dx} = 0
oh. does it have any meaning?
because somehow, it is manipulated to become the compressibility of the gas. k = -1/v (dv/dp) = 1/p.
it reminds me of the momentum = mv which became mdv + vdm.
so does it mean anything the equation pdv + vdp ?
But you don't need to use that relation to get the compressibility. You only need to find the derivative (\partial V / \partial P)_T using the ideal gas law.
aren't they the same?
pdV is pressure times an infinitesmal change in volume while Vdp is volume times an infinitesmal change in pressure. There's no obvious reason why they should be equal aside from the derivation.
Since work is given by \int pdV in some situations it may be more convenient to calculate \int Vdp
Here's my interpretation of the meaning: if the temperature of the gas remains constant, then so does its total internal energy. If so, then this must mean that:
energy lost = energy gained.
-pdV = VdP
We can interpret PdV as the infinitesimal work done by the gas on its surroundings (a source of loss of internal energy if the work is positive). Similarly, we can interpret the term VdP as the internal energy gained through heat flow (heating a gas at constant volume will increase the pressure, which is proportional to the energy density). So, you could interpret this equation as saying that if the temperature (and therefore internal energy) of an ideal gas is to remain constant, then any energy loss by work done on the surroundings must be exactly balanced by energy gained through heat flow.
