Ideal Gas Equation and Temperature change?
In a thermodynamic process involving an ideal gas, the state variables change with pressure doubling, volume tripling, and temperature increasing by a factor of eight. The discussion centers around calculating the temperature increase, T2 - T1, with an initial answer of 4780. Participants emphasize the importance of converting Celsius to Kelvin before applying the ideal gas law, PV/T = constant. There is a consensus that the problem resembles homework quality, suggesting it should be approached with proper methodologies. The thread concludes without a definitive solution, highlighting the need for correct unit conversion.
HannahJB
During a thermodynamic process, the state variables of an ideal gas, measured in kPa, m3, and oC, varied in the following way:
P2 = 2P1
V2 = 3V1
T2 = 8T1
What is the temperature increase of the gas, T2 −T1 ?
I've been given an answer of 4780 and I'm not sure how to get there?
Science news on Phys.org
Is this a homework problem?
No it was an old question in an lecture that I still don't understand
Did you try just using the fact that PV/T is constant?
Yes but I still can't get the answer that was given
Well, according to you, the temperatures are given in Celcius. Did you first convert them to Kelvin before using PV/T = constant?
Even if it should not be actual homework, it is of homework quality and should be handled there, the usage of our template included.
Thread closed.
