How Does Doubling Volume and Increasing Temperature Affect Gas Pressure?
Doubling the volume of an ideal gas and increasing the temperature to 50 degrees Celsius affects its gauge pressure, which can be calculated using the Ideal Gas Law (PV = nRT). At standard temperature and pressure (STP), the initial conditions are 6.00 L at 0 degrees Celsius and 1 atm. To find the new pressure after the changes, the temperature must be converted to Kelvin, and the new volume must be considered. The Ideal Gas Law provides the necessary framework to solve for the new pressure. Understanding these relationships is essential for accurately determining gas behavior under varying conditions.
Shakerhood
An Ideal Gas occupies a Volume of 6.00 L at STP. What is its Gauge pressure (in kPa) if the Volume is doubled and the Temperature is increased to 50.0 Degrees Celcius. I don't know where to begine as the question doesn't have a starting Temp, just that it was increased to 50 Degrees Celcius. Any help is greatly appreciated!
STP stands for standard temperature and pressure. it is 0 degrees C and 1 atm.
Do you have an equation for me that might help?
The Ideal Gas Law should cover this.
I have a really Sorry Book, I will try to find that in there. Thanks!
The Ideal Gas law says in an Ideal Gas in a closed system the following relation always holds constant,
PV = nRT
P = Pressure
V = Volume
n = number of moles
R = The gas constant
T = Temperature (KELVIN)
http://hyperphysics.phy-astr.gsu.edu/hbase/kinetic/idegas.html"
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
