If a block is moving and then hits a spring, is the work negative?
When a block moving to the right compresses a spring, the work done by the spring on the block is negative. This is because the displacement of the block is in the opposite direction to the force exerted by the spring, which acts to the left during compression. As the block compresses the spring, it loses kinetic energy, confirming that the work is negative. The consensus in the discussion supports this understanding of work and energy in the context of spring mechanics. Thus, the work done by the spring is indeed negative.
PhyIsOhSoHard
Say there is a block that moves to the right. After a distance it hits a spring, and then it compresses the spring. Does this mean that the work that the spring does on the block is positive or negative?
I would say it is negative because the block compresses the spring, so the displacement which is to the right is in opposite direction of the spring force, which during compression is trying to push the block to the left.
Am I correct?
Am I correct?
Sure, the block loses kinetic energy. So the work the spring does on the block is negative.
Likes 1 person
Am I correct?
Yes!
Likes 1 person
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
