I'm second guessing myself on Limits
  • Thread starter Thread starter Ithina
    Limits
The discussion centers on whether the expression [1 - (U^2/W^2)]^(-1/2) can equal zero. The user explores the scenario where (U/W)^2 approaches infinity, leading to a limit analysis. They conclude that as (U/W)^2 tends to infinity, the expression approaches zero, despite the involvement of the imaginary unit 'i'. The conversation emphasizes that squaring both sides of the equation does not affect the limit outcome. Ultimately, the user is grappling with the implications of real versus imaginary results in this limit context.
Ithina
Can [1 - (U^2/W^2)]^(-1/2) equal 0?
I don't think the other equations are needed.. This is just a tangent of mine from last Physics' lecture.
I set the (U/W)^2 part to infinity.
0 = 1 / sqrroot(1 - infinity)
which is:
0 = 1 / infinity*i
I know (1/infinity) goes to 0, but does the (i) change anything other than make it not real? I'm not worried if it's real or imaginary at the moment.
you're right it is a bit different however as you see you could always just square both sides which shouldn't make a difference to the limits and you'll still see that it limits to 0 (from the negative)
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
