There's another important piece of missing information: The length of the board. Why are these two pieces of information important?
You cannot solve the problem without knowing the length of the board. Suppose the board is 30 cm long. That means the board must be pitched straight up if the top is to be 30 cm above the table. The ball will have no horizontal velocity when it leaves this minimal length board, and thus the ball will have zero horizontal distance between leaving the edge of the board and hitting the floor.
Now suppose the board is longer than 30 cm. When the ball leaves the board, some of its rolling velocity will be directed downward and some horizontally. The ball will travel. How far depends on the magnitude of the exit velocity and the direction. While the direction is solely a function of the setup (i.e., the angle of the ramp), the exit velocity is a function of both the setup (i.e., the height of the board above the table) and the nature of the ball. Try your experiment with a super ball, a tennis ball, and something like a Hot Wheels car.
The key word here is "rolling". Ignoring friction, the super ball, a tennis ball, and model car will all gain the same amount of kinetic energy as they roll from the top of the ramp to the bottom, and in an amount equal to the decrease in potential energy. (i.e., mgh). However, how this kinetic energy is distributed into rotational and translational energy depends a lot on the makeup of the object. The model car's wheels don't have much rotational kinetic energy, so almost of the kinetic energy will be in the form of translation. This is not the case for the tennis ball or the super ball. A good chunk of the kinetic energy goes into rotation, and that rotational kinetic energy does not contribute to the motion of the ball after it leaves the track. The car will go considerably further from the table than will either ball, and the super ball will go somewhat further than the tennis ball. If you have studied moment of inertia you will know why. If you haven't studied that yet, the instructor had no business talking about "rolling".
