Implicit Differentiation Problem
Vigo
Consider the curve given by X^2+4y^2=7+3xy
a) show that dy/dx=3y-2x/8y-3x
b) show that there is a point P with x-cooridnate 3 at which the line tangent to the curve at P is horizontal. Find the y-cooridnate of P.
c)find the value of d^2y/dx^2 at the point P found in part (b). Does the curve have a local maximum, a local minimum, or neither at the point P? Justify your answer.
(a) is easy. All you do is find the derivative.
For (b), I got the point (3,2) by plugging 3 into the original equation and got 2.
For (c), the value I got was -2/7 by finding the second derivative and plugging (3,2) for the x's and y's. I need to know if this is right and if there are any max's or min's at this point. Thanks.
-2/7 is correct. You know that dy/dx is 0 at the point, so you know it has to be either a maximum, a minimum, or a saddle point. Intuitively what do you think it should be, given that d^2y/dx^2 is less than 0? If it is less than 0 it means that the slope is decreasing--the slope is changing to become more negative. What would that mean in terms of maximum or minimum?
Slope of dy/dx is decreasing and is 0 at x= 3. That is, dy/dx is positive for x< 3 and negative for x> 3. y itself is increasing for x< 3, and decreasing for x>3. What does that tell you?
Since y is increasing when x<3 and decreasing when x>3, does that mean there is a local maximum?
Yes. Draw a picture of that situation.
Alright, thanks a lot for all of your help. I believe this graph looks like a slanted ellipse.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
